2K4 Accord SRS lamp on. Removed P/S front seat broke wires
Old Oct 6, 2021 | 03:03 PM
Phoneman63's Avatar
Default 2K4 Accord SRS lamp on. Removed P/S front seat broke wires
Hi all,
I removed the P/S seat to replace the downstream O2 sensor on my daughters car w/o removing the connections under it. I leaned on the seat and ripped out some wires from the connector that plugs into a module under the seat. The connector has 3 wires and plugs into the 1st port of the module left to right. The wires have a yellow wire loom protecting them. Can someone tell me what the name of the module is? What is the connector that plugs into the module controlling? And where can I get a replacement pigtail or harness? Also will the airbags still work?
Any help will be much appreciated!
Alex
Old Oct 6, 2021 | 04:28 PM
Yellow wires are typically the air bag system, so you likely damaged the harness to the side airbags that are part of the seat.
Dagonus
Nov 13, 2020 09:34 AM
Frugalhondaguy
Jul 1, 2016 06:53 AM
mach196
Sep 24, 2015 07:33 AM
brauhaus348
Jul 19, 2012 08:31 AM
Bjm5295
Aug 12, 2010 06:40 AM
