2nd Battery Install
Old Jan 17, 2010 | 11:54 AM
evolive's Avatar
Default 2nd Battery Install
Hi,
Did a search could not find any information regarding this.
I would like to install a 2nd battery so that I can hook up a small portable heater. I plan on sleeping in car in the snow (Mammoth).
I just wanted to get a few information right before I attempt to move forward.
I would like to be able to charge the battery with the car so I'd assume I have to run the 2nd battery in parallel with the 1st one. But since I will be running the heater while engine is off... I should get some sort of relay or "switch" to disconnect the connection between 1st and 2nd battery (to avoid draining 1st).
Would this be something that will work out? Is a car battery good enough to power up a small portable heater (do you recommend any heaters?)
How long will I be able to run the heater for? It seems that small heaters on amazon.com are 750w to 1500w... my ac-dc converter is 1400w
Whelp... let me know guys. Would love to get this started
Old Jan 18, 2010 | 09:43 AM
750 watts means 63 amps.
What's normal for a car battery, 150 or 200 amp-hours? So that's only a couple hours (maybe 3) before that battery is DEAD. Long before it's dead, the voltage will go low so the heater won't work well.
I'd probably use a good sleeping bag, the car is better shelter than a tent. Backpacking stores will have stuff that's good for winter camping. I've done that in North Dakota in February.
Old Jan 29, 2010 | 08:35 PM
hondadude's Avatar
You might have good luck going to some of the RV websites, or google search "battery isolator"
http://www.powerstream.com/battery-isolator.htm
cadams8221218
Jul 15, 2011 07:24 AM
MAPULENTO
Feb 12, 2007 08:32 AM
RoKnAzn
Jan 19, 2007 01:56 PM
mikec
Sep 5, 2006 11:25 PM
downshifter
Jul 26, 2006 12:31 PM
