3 engine codes: P0135, P1739 and P0171
Old May 12, 2015 | 06:10 PM
Osker15's Avatar
Default 3 engine codes: P0135, P1739 and P0171
I already know what the codes are, I want to do most of work myself. I want to know what the least expensive approach to fixing the codes would be. I was thinking of cleaning the fuel injectors and changing the transmission fluid. I have a 1998 Honda Accord by the way.
Old May 12, 2015 | 08:44 PM
V6 or 4 cylinder? The 01739 is for an automatic transmission.
You need to do some diagnostic work to figure out the actual problem(s).
P0135 is the heater circuit of your O2 sensor, so you would want to measure the resistance on the O2 sensor to see if the heater circuit is open. This could also be a wiring problem.
P0171 is a lean condition, so there is too much air or too little fuel. Do you have a scan tool that can read fuel trims or O2 sensor output?
The P1739 is for the 3rd clutch pressure switch. You would need to test if the switch is bad. This could also be due to wiring or something internal in the transmission.
Old May 12, 2015 | 10:21 PM
Osker15's Avatar
It is a 4 cylinder. I am most likely going to get it diagnosed tomorrow morning. I'll update with what they tell me.
Old Oct 19, 2019 | 01:10 PM
Alex 'Kimo' Hawk's Avatar
Default Any update?
Aloha.. Having a similar problem.. Done too many things in the past year to list right now.. But, any update on what happened? Mahalo!
Old Nov 16, 2019 | 12:20 AM
Default Nevermind.
Ok. Nevermind then. I fixed it.
rtaksokhan
Nov 4, 2023 05:56 PM
N1Accord
Sep 20, 2017 05:47 PM
jefe722
Aug 7, 2014 12:27 PM
philiam
Jan 7, 2009 01:43 AM
vvv_vtec
Feb 17, 2008 01:48 PM
