5th gen Fuel gauge question
Old Jan 30, 2016 | 01:11 AM
Mr_Sancho's Avatar
Default 5th gen Fuel gauge question
Just bought my very first car back, 1995 V6 accord, and am fixing it up little by little. One thing that I knew was wrong when I sold it was the fuel gauge, it broke when taking off the indigo gauges.
So now I've resorted to buying a replacement on eBay but keep coming across bad gauges. Or at least that's what I think. My gauge that is broke won't return to empty. I've pulled the gauges apart and manually moved it back to empty to see if it goes up, which it does.
I've now bought 2 online that do the same, won't return. And this is of course when the power is off.
I can't rule out a faulty sending unit now but if I remember correctly, the fuel gauge would rest at empty when the car was off. And this is what an aftermarket gauge I had on it does too. My other cars do the same thing, return to empty when not on.
Could someone with a working fuel gauge confirm this is what the fuel gauge does on your accord? Does your gauge return to empty when not on?
Thanks!
Old Jan 30, 2016 | 09:00 PM
UhOh's Avatar
Thanks!
1997 Accord, 4 cyl. here. Been sitting for 1 1/2 hours.
Went out and checked, fuel gauge registers just under 1/2 tank,
so fuel gauge retains its setting when ignition is off. Hope this helps.
Old Jan 31, 2016 | 11:09 AM
See attached file for guidance in testing your gauge.
Manual confirms that gauge does not return to empty.
File Type: pdf
Old Jan 31, 2016 | 07:16 PM
Mr_Sancho's Avatar
Awesome. Thank you both.
Elk Hunter
Oct 2, 2012 11:08 AM
coolcat
Nov 24, 2008 08:39 AM
Ponyboy
Jun 1, 2008 01:13 PM
finch13
Apr 15, 2008 10:13 AM
thenewguy10
May 15, 2007 10:56 PM
