87' Accord DX idling high?
Old Dec 13, 2012 | 08:58 PM
oldtimewine's Avatar
Default 87' Accord DX idling high?
I replaced the carburetor on my 87' accord this morning and now it is idling very high(between 3-4 rpm) I thought it may be the fast idle but when i eased off of the clutch it pulled like i was giving it gas but my foot wasn't on the gas pedal. I dont know if i hooked up a vacuum hose wrong or something. I would greatly appreciate any help you guys could give! Thank you
Old Dec 14, 2012 | 08:56 PM
Well, you want to start with checking the vac lines. Next be sure the choke is opening properly.
Is/was this a used or a reman carb?
Old Dec 15, 2012 | 10:10 AM
re manufactured. the choke is opening properly but ill check the vacuum lines
Old Dec 15, 2012 | 08:29 PM
all vacuum lines are in the correct place. it's acting as if it's getting too much gas..
Old Dec 16, 2012 | 09:26 AM
Be sure the choke is opening all the way.
Is the alt/charge warning light on?
You might need to set the idle speed, since this is a reman unit I don't think they would have set it.
Old Dec 16, 2012 | 09:33 AM
the choke is opening and the alt/battery light isnt coming on. How do i go about setting the idle speed?
Old Dec 16, 2012 | 10:33 AM
Be sure the throttle cable is going "slack".....then the idle adjustment is on the back side (firewall) of the carb.
Old Dec 16, 2012 | 08:57 PM
there are 2 screws,one on each side of the carb. Do you know what they are for? my father came and adjusted what he thought was the idle adjustment but ended up being those screws. thanks for the diagram btw
Old Dec 17, 2012 | 07:15 PM
....pic's? I'm trying to think/remember what/which ones you are talking about.
I "think" the mixture and fast idle are on the "side" but really can't remember right now.........sucks getting old.
PepeLePew
Jun 2, 2012 10:49 AM
MICHOASTYLE
Mar 15, 2012 06:16 PM
ninjadog
Mar 23, 2011 09:45 PM
yamahabalu
Sep 28, 2009 02:11 AM
coupe_hybrid
May 31, 2006 10:11 PM
