87 honda accord firing on 2 cylinders
Old Jan 22, 2012 | 10:58 PM
losthondaguy's Avatar
Default 87 honda accord firing on 2 cylinders
i have a 87 honda accord lxi so its fuel injected and i put a new head on it because it had a cracked head, the head i pput on it is exactly the same as the old one, i have all the timng perfect and have checked just about everything but pistons 1 and 4 arent firing for some reason, (although we are diesel mechanics) ive had several mechanics look at it and none of us can figure it out, it runs fine on just 2 and 3 but i cant get it to idle worth a s**t, i have been working on this damn thing for 3 days strait and am getting very frusterated. has anyone else had this problem? i need some serious help? Any ideas will help. much appritiated.
Old Jan 22, 2012 | 11:06 PM
How are you verifying that cylinders 1 and 4 are not firing?
Old Jan 23, 2012 | 03:08 PM
because i pulled the plug wires on them and it doesntmake it run any different, it had spark just vary lame spark, so i assumed they were not firing.
Old Jan 23, 2012 | 04:08 PM
Hook a timing light up to one spark plug wire at a time. See if enough spark is generated on each wire to flash the timing light.
Old Jan 23, 2012 | 05:24 PM
While at it, check for voltage to the injectors.
Old Jan 25, 2012 | 03:23 PM
thanks alot for the input but i figured out that my egr valle was stuck open causeing a huge vacuum leak making it run like ****. so i fixed that and now it runs great.
96A
Dec 23, 2014 11:30 AM
mcdonald109
Dec 5, 2011 11:27 AM
teamBOMB
Jul 24, 2011 03:44 PM
jthompson055
Jun 3, 2011 01:40 PM
wildwildoates
Apr 13, 2011 07:38 AM
