'88 Accord Won't Run After Long Storage
Old Jun 23, 2009 | 10:42 PM
Tom M
Default '88 Accord Won't Run After Long Storage
Our 1988 Honda Accord DX, after having been parked for many months, will not run unless you feather the gas or hold the choke closed on the carb; If you try to hold the throttle steady (like normal) it dies.
We've tested the fuel pump and it seems to be working fine.
We have put good gas in it, rebuilt the carburetor, replaced hoses and the PCV valve with no luck.
Old Jun 23, 2009 | 10:52 PM
hondadude's Avatar
rebuilt the carburetor?? Complete?
Did you blast out the idle ports with Berrymans B-12?
Can you hear the idle solenoid click when the key is turned on?
Fuel level 1/2 way in the sight glass?
Throttle plate hanging open ??[bottom of the carb barrel]
Did a rat chew up a vacum line while it was in storage?
Carbs are just one of those things that are hard to fix over the internet.
drewklos
Mar 31, 2014 02:18 PM
GolfNut
Nov 4, 2013 06:46 PM
pressman1948
Jul 30, 2013 06:09 PM
mmgehrig
Jan 28, 2013 10:05 PM
krob111
Oct 9, 2006 03:50 PM
