89 accord update: FUN
Old May 26, 2014 | 02:53 PM
huntersdl's Avatar
24mm is what I meant stupid autocorrect
Old May 27, 2014 | 07:06 PM
Sorry, what is leaking - the oil pressure switch or something else?
Old May 28, 2014 | 07:54 PM
huntersdl's Avatar
Appears to be coming from the pan...hard to be 100percent on the switch cause it wont drip unless hot and I cant see it good without my phone camera and I keep burning my hands trying to get a good look..
Old May 29, 2014 | 07:32 PM
huntersdl's Avatar
Default switch
If I want to go ahead and take switch out how do u recommend? I wonder how tight that thing is because I was thinking of a hand wheel ratchet. Wasn't sure what would fit over the nipple that the wire attaches to
Old May 30, 2014 | 05:48 PM
I hate replacing if you are not sure. Did you clean the back side of the block and have a good look?
IF you want to replace the switch. The boot and wire come off - yes the boot is prob going to give way....it is rubber, been there for ~25 years in a lot of heat cycles. Most parts stores rent, sell oil pressure switch sockets. If you still have issues getting to it you can remove the oil filter for a bit more room.
The threads are "pipe" threads. So in theory you do not need to use sealant on them - plus the switch has to ground via the threads to the block. The tourque is not much (13 ft lbs, about the same as spark plugs - snug).
Fat Ryan
May 4, 2013 04:16 PM
Cody_754
May 12, 2012 12:18 AM
austinman3214
22
Mar 15, 2010 07:18 PM
TailsnessAccord
Nov 7, 2006 05:38 PM
remington870_20ga
May 15, 2005 02:00 PM
