89 Honda Accord LXI Fuel Problem
Old Jul 7, 2016 | 11:03 AM
weedog's Avatar
Default 89 Honda Accord LXI Fuel Problem
I have a 1989 accord that I replaced the head gasket on. The problem I have did not do this before I replaced the head Gasket. Do you think it has something to do with the fuel rail I did replace the o rings on it .Since I replaced the head gasket 6 times out of 10 when I try to crank the car its like it flooding with a miss for about 15 to 20 seconds you have to hold the gas pedal down half way to it clears up then it runs find
and some times out of that 6 out of 10 it will just spin over and never hit a lick I mean like it is not fireing .Could someone PLEASE help me find the problem. THANKS
Old Jul 9, 2016 | 05:32 AM
Are all of the tune up items up to date.
What is the compression of each of the cyl's.
Old Jul 21, 2016 | 10:14 AM
weedog's Avatar
The Problem With The Car Did Not Start Until The Head Gasket Was Replaced. Never Had The Problem Before Thanks
Old Jul 21, 2016 | 04:33 PM
Suggest treating as a no-start when it occurs.
Try spraying 5-10 secs of starter fluid or throttle body cleaner into air intake when no-start occurs. If engine starts briefly, then fuel delivery problem; fuel pump problem likely. If it still won't start w/ starter fluid, then ignition fault is causing no-start; intermittent coil or ignitor, cracked distributor cap/rotor.
weedog
May 26, 2016 12:51 PM
visualsmoke
Nov 10, 2013 06:31 AM
dderolph
Oct 7, 2011 11:36 AM
Honda Enthusiast
Feb 15, 2011 08:43 PM
phil
Apr 5, 2009 07:15 AM
