89 honda accord won't start
Old Feb 24, 2013 | 02:33 PM
Melody Goodwin's Avatar
Default 89 honda accord won't start
my 89 accord turns over more rapidly than usual but won't start. PLEASE HELP
Old Feb 24, 2013 | 05:39 PM
Does it just sound like fast spinning with no sound of each cylinder coming up on compression? What about a broken timing belt?
Old Feb 26, 2013 | 04:36 PM
Is it very difficult to change the timing belt, I'm sure it's overdue for it's second ?
Old Feb 26, 2013 | 05:07 PM
Not too bad on a 89 Accord....the biggest concern is going to be about the valves. Hope, pray that they did not get bent if the timing belt went.
Can you pull the top timing belt cover off and check the belt?
Old Feb 27, 2013 | 10:31 AM
Melody, I deleted your other post because it was in a completely unrelated thread. Like Poorman says, the bigger question is whether your valves are bent.
Old Mar 3, 2013 | 07:28 PM
Default RE: 89 Accord
I also had a miss in it, after a heavy rain. Do U possibly think it could distributor related, since the car hasn't started since one of last months heavy rain ?
Old Mar 4, 2013 | 10:18 AM
I think the question about bent valves is most important. Assuming the starter can crank the engine, I would take out all sparkplugs & measure compression. That would put away our GUESSING about bent valves. We can't hear it from here, so we only have your statement about it turning over more rapidly.
Then you can test for spark?
Old Mar 5, 2013 | 05:47 PM
I really appreciate your response. Now I follow your direction, I need all the guidance I can get. Many Thanks Again.
Tony1M
Nov 6, 2023 08:29 PM
Sheri6889
Jun 17, 2015 08:19 AM
gaas12
Jan 5, 2007 06:45 PM
2ManyHondas
Sep 23, 2006 05:11 PM
