90 accord f22 mystery
Old Jun 27, 2015 | 12:47 PM
Wesserman's Avatar
Default 90 accord f22 mystery
Ok guys I am new to forum posts so bear with me, I have a 90 accord with the f22 and it has a rough running problem, the injectors seem to be testing ok the compression checks out within specs and I have spark but when I pull off cyl 1 and 2 plug wires there is no change in the way it runs. It's only running in cyl 3 and 4 that I can tell and I'm kinda leaning towards the fuel pump, but any suggestions on what to do or anyone's experiences would be greatly appreciated ! Thanks!
Old Jun 27, 2015 | 06:20 PM
What compression readings are you getting?
How did you check the injectors?
Old Jun 27, 2015 | 11:44 PM
Wesserman's Avatar
Compression is consistently 170 on each cylinder and I checked the key on voltage on each plug to the injectors,and checked the resistance of each injector,all were the same.
Old Jun 28, 2015 | 01:45 PM
A resistance test on the injectors doesn't rule them out. Probably the easiest way to rule out injectors is to switch them with a good cylinder and see if the power balance test results are the same.
I wouldn't jump to the fuel pump until you do a fuel pressure test. Your accord has an access port on the rail. You may be able to get a loaner tool from a parts store with the proper adapter.
maverick2k7
Feb 5, 2011 08:59 PM
AbaZ
18
Jul 16, 2008 10:23 PM
swayzak
Feb 22, 2008 11:27 AM
SpanishN00b
Jul 29, 2007 07:11 PM
avrillu
May 17, 2006 09:14 PM
