90 Accord fuel or ECU problem?
Old Jan 1, 2013 | 05:39 PM
motogar's Avatar
Default 90 Accord fuel or ECU problem?
First thread folks, correct me if I do it wrong.
I ran my 1990 Accord fuel level low untill warning light, since that time I have what acts like a fuel starvation problem. Bogging, no power.
This problem occurs at about the same point of operation every time the vehicle is restarted. The problems is for a short duration, and the motor clears and runs fine. Fuel pump and screen, fuel and fuel filter have been replaced. There has been an occasional "chk engine" light, that resets after operation. I have not check stored codes. I was hoping for the magical fix!
Old Jan 1, 2013 | 07:43 PM
Check Engine light codes must be determined to diagnose. See DIY forum for guidance on Obd1 code extraction.
Magic fixes are guesses and can be expensive. If this is a "cold engine" only problem, I would suspect a false input; Inlet Air Temperature or Coolant Temperature. The CEL code should identify the problem.
Old Jan 2, 2013 | 12:37 AM
Hi New Member.
Your now in the correct thread to post these kind of questions.
Thank You for joining the HAF...
Old Jan 2, 2013 | 08:46 AM
motogar's Avatar
Thank you for the replies, I will be checking codes to diagnose more. I was crossing my fingers on the quick fix.
Old Jan 2, 2013 | 12:43 PM
Keep your fingers crossed, it MIGHT STILL be a quick & easy fix. But without knowing the error codes, we have way too many possibilities to guess.
live2rice
Sep 20, 2012 02:26 PM
Dave Clark
Aug 25, 2012 06:31 PM
98accordman
Nov 22, 2010 08:03 PM
australi
Nov 7, 2010 05:21 PM
hurraquio
Dec 7, 2007 02:09 PM
