'90 Accord LX brakes... HELP PLZ!
That is just the taillight lense, that would not be the part.
Right side would be Honda Part Number: 37540-SM4-A01. It is the little box like in the previous images I posted.
Edit: My mistake, your PM said right side (passenger side).
Here is a test if you want to try. Verify the wire colors first.
Unplug the 8-gray connector (connector C715) shown in the attached image. With a wire or small paper clip, jump the 8P connector female terminal cavity (where the Grn/Wht wire is) to the female terminal cavity (with the Grn/Yel wire). The Grn/Wht wire is a wire with green insulation and a white stripe running through it. Depress the brake pedal; does the high mount brake light work?
You can then jump the Grn/Wht wire female terminal cavity to the Grn/Red wire female terminal cavity. Then depress the brake pedal, does the right inner brake light work?
If they work this way, you probably have a faulty brake light failure sensor.
Okay. I took my '90 Accord into the shop for a bumper to bumper inspection ...
They did tell me that I had a tail light out, so ... Am I missing something here?
I checked the light bulb and it's fine. I checked the fuse and it's fine.
Please help me figure out what to do from here.
To the OP, don't take your car back to that shop.
Your local Honda dealer is the best normal solution to false mechanical claims.
She had previously contacted me via PM to state an issue with the "right brake light".
alphaney
Feb 12, 2022 10:14 AM
thunder_x
Sep 27, 2006 11:00 PM
