90 Accord spewing oil from the distributor
Old Sep 11, 2010 | 01:09 PM
HondaNooblet's Avatar
Question 90 Accord spewing oil from the distributor
i have a 1990 Honda Accord and it is spewing oil from the distributor. it happend once already and i replaced the distributor and less then a week later its doing the same thing. i can turn the car on and see the oil spewing from the bottom of the distributor. i also changed the pcv valve since the old one was plugged. im just trying to see what i can do before spending more then the car is worth to fix it.
Old Sep 11, 2010 | 01:39 PM
deserthonda's Avatar
did you install a new o-ring at the base of the distr where it goes into the head??
Old Sep 11, 2010 | 02:00 PM
yes i changed it twice, the guy at the local parts store said it might be a pressure problem caused from the rings. he also said that as i was trying to return the distributor, which he would not take back because he said the distributor dont fail. so im out 200.00 buks already.
Old Sep 11, 2010 | 04:10 PM
chk the area around it,, chk for possible small cracks on the head, valve cover gasket ??
i have never seen oil really gush out from the distr ,, i have seen it leak but not like you are experiencing
got the correct distr + o-ring ??
Old Sep 11, 2010 | 05:47 PM
yes, its the right one and the oil is spewing from the vent like the pressure has blown the seals.either that or i got two defective distributors.
Old Sep 11, 2010 | 07:34 PM
Mikebike125's Avatar
Deserthonda, Is his PCV valve stuck closed/clogged and the pressure has found a different way out??
brjr1
Aug 12, 2010 09:56 AM
lappy35
Mar 27, 2010 07:00 AM
JTK
Jun 22, 2008 08:04 PM
joelanier
Mar 11, 2008 08:06 AM
UGLYTRUK
Nov 5, 2006 01:32 AM
