90 Accord transmisson
Old Jun 22, 2015 | 06:25 AM
The Lock-Up Control solenoid only locks when voltage is applied. So disconnecting LU soleoid A/B (they are integral) will test whether lock up is an electrical or hydraulic problem.
If disabling h as no effect, the problem is likely a mechanical failure of the lock up torque converter and will require transmission repair.
If disabling prevents lockup, then problem is an electrical short to a voltaage source or faulty TCU.
Old Jun 22, 2015 | 07:48 AM
honda90's Avatar
Hello, I went and started up the honda and let it warm up in N with E brake on.
After 45 minutes I shifted into drive and it lunged then the engine died.
I jumped the blue connector orange/red to green/white.
The code reads 1 short flash.
Old Jun 22, 2015 | 08:45 AM
Good News! Fault 1 is an electrical fault of LU control solenoid. See my previous post to determine if fault is in electrical connector, wiring, or TCU.
Tylor Briery
Oct 25, 2012 09:32 PM
91sihatchback
Oct 23, 2010 12:28 AM
Accord DX
Jun 20, 2008 05:02 PM
blackaccrd97ex
Jan 14, 2007 07:31 PM
2002haccord
Sep 26, 2006 09:57 PM
