91 accord engine coolant sensor issues
Old Dec 9, 2011 | 10:30 PM
davemullins2010's Avatar
Default 91 accord engine coolant sensor issues
I have a 91 accord, lx.....CEL came on and jumped it and code was #6....changed the sensor under the distributor...reset ECM...still gives code 6...any ideas what the issue may be?
Old Dec 9, 2011 | 11:43 PM
There are a couple of sensors under the distributor. How many wires were going to the sensor? What were the wire color(s)? What was the color of the plastic electrical connector?
Old Dec 10, 2011 | 09:30 AM
well there are 3 of them near the ditributor.....the only one that matched the size of the sensor i purchased from auotzone was the one directly under the distributor....seems like there is a pre coolant intake sensor and a post...one from the lower heater hose and one on the upper heater hose.....those 2 sensors were way bigger but the plugs were the same. If it helps i replaced the one next to the sensor that sends the temp to the dash. Hopefully if i can find out what the problem is since its not this sensor than my car will start when its cold outside...and not take 10 minutes to get running.
Old Dec 10, 2011 | 12:07 PM
So the sensor you replaced had a two wire connector going to it?
pondrun
Nov 8, 2021 09:40 AM
lecola
Jan 10, 2013 06:30 PM
bobbyc1968
Dec 4, 2012 04:02 PM
jhbigred
Dec 11, 2011 11:47 PM
jared8783
Aug 15, 2011 12:06 AM
