91 accord: severe idle problem
Old Jan 31, 2009 | 04:55 PM
jackfast's Avatar
Default 91 accord: severe idle problem
only when warm; rythmic fast/slow, fast/slow...
like a huge vacuum leak, but i cant find anything unattached.
cleaned the EGR valve, to no effect.
otherwise starts, and runs fine.
idles fine when cold.
any ideas?
Old Feb 1, 2009 | 08:44 AM
Check PCV valve for sticking open and PCV hose for splits/leaks. Clean the Idle Air Control Valve, throttle body entrance, and backside of throttle plate w/ throttle body cleaner.
See DIY section for guidance and try search function for "clean iacv".
Old Feb 1, 2009 | 04:19 PM
obriener2054's Avatar
best take off the tb and give it a good clean with carb cleaner...
check around the inlet, have you an egr plate??? has the gasket on the inlet perished???
is the tb cable in good order, not sticking, and how is the spring on the tb
HTH
Noel
Old Feb 1, 2009 | 07:50 PM
jackfast's Avatar
Default fixed!
Cleaned the Fast Idle Thermal Valve (FITV) and tightened the ring inside the valve; idles fine now!
thank you!
this link was exceptionally helpful: http://www.cb7tuner.com/vbb/showthre...highlight=idle
Gaven 5
May 18, 2015 06:25 PM
accordpos
Jan 12, 2013 06:55 AM
netlace
Mar 25, 2010 06:58 PM
keno16
Jan 24, 2009 07:00 AM
