'91 Accord speedometer/odometer quit
Old Mar 13, 2008 | 07:32 PM
pfrathjr
Default '91 Accord speedometer/odometer quit
The speedometer and odometer only work for brief periods. Any ideas? Thanks!
Old Mar 14, 2008 | 01:45 PM
accord4sroy's Avatar
Default RE: '91 Accord speedometer/odometer quit
Well, a lot of folks on here have mentioned a bad VSS (Vehicle Speed Senor). So, that could possibly be the issue. I am sure more responses will come soon. A lot of knowledgeable people in this forum.
Old Mar 14, 2008 | 03:50 PM
00AccordLX5spd's Avatar
Registered User
See if your cruise control works when the speedometer doesn't work. If the cruise does not work when the speedometer works, it is probably the VSS. If the cruise control still works when the speedometer doesn't work, then it is probably not the VSS - it is probably something internal within the speedometer.
Also if you have a bad VSS your check engine light should be on.
Tony1M
Nov 6, 2023 08:29 PM
BSims66173
Nov 9, 2012 11:52 AM
9DEX
Oct 9, 2011 08:46 PM
jackmd
Sep 15, 2011 06:11 PM
Driver 1
May 25, 2011 11:33 PM
