Question about heat
Question about heat
So on my 97 accord I turned the **** from cold to hot and felt something let go and there's no heat. I was thinking it was the cable that goes to the heater control valve, so I went under the hood and manually moved the valve and still no heat, so then I took it off and turns out it is functioning properly, so heater valves back on and open. Is there a flap or something in the dash that the **** turns to change from hot air to cold air as well as move the cable? That's the only thing I can think of. Do I then have to take the dash apart to fix it. I need to fix this quick before it gets cold again. Thanks.
Check that the **** you turn didn't crack.
I think the cable from the heat **** controls the coolant valve in the engine bay and also the air mix door. The common diy thread on top of the gen tech forum has a link to online shop manuals. The hondahookup site has a 94 shop manual you can download. The heater unit is the same as your 97 accord.
The **** I was talking about is the one you turn with your hand to adjust the heat. The **** just pulls off. It is not uncommon for them to crack. It is a quick and simple test.
If that **** is ok, then you will have to get into the dash and look at the attachment points of the cable that is adjusted by the heater control.
skijour
08-15-2012 08:31 PM
