No heat
Old Nov 24, 2005 | 01:47 PM
misterluh
Default No heat
Hey y'all. weirdest thing happened yesterday morning. about 15 min. into my commute, which by this time the car is warmed up to operating temperature, I notice that I have no heat. It dropped down to the 50's here in south florida (I know I shouldn't complain) so I needed a little heat. Here were my settings: defrost/foot button on, fan at level 1 or 2, thermostat at 3/4 (halfway into the "red" or heat zone). the air coming out was ice cold even at full red. checked all the fuses and they're good. checked again this morning: let the car warm up, tried defrost, AC, everything, both cold and hot and everything in between and now it works. will get on expressway later to try it again.
I find it hard to believe that the cooler temps yesterday morning would affect this in anyway. I did notice that while driving my temp gauge was a little less than half (more to the cold side) than normal which is exactly halfway.
Old Dec 3, 2005 | 01:22 AM
soldierforchrist2
Default RE: No heat
Have you checked if the thermostat is sticking? Although if it was that hot I wouldn't think that would be the problem.
Old Dec 3, 2005 | 11:02 PM
deserthonda's Avatar
Default RE: No heat
start car up let it wqrm up, hold the lower radiator hose and make sure it is hot . if it feels cool or just lukewarm replace the t-stat,,,,,,,,,if hose is hot, chk the heater valve cable adjustment make sure that the inside heater **** is not broken first of all and that when all the way on hot it opens the heater valve fully
skijour
Aug 15, 2012 08:31 PM
Cessna172
Nov 5, 2010 01:22 PM
vince_carnovale
Jul 18, 2008 07:38 PM
junobear
Apr 5, 2006 07:08 PM
eckhart
Mar 29, 2006 09:43 PM
