Question about heat
Old Jan 26, 2018 | 07:28 PM
HighwayStar's Avatar
Default Question about heat
So on my 97 accord I turned the **** from cold to hot and felt something let go and there's no heat. I was thinking it was the cable that goes to the heater control valve, so I went under the hood and manually moved the valve and still no heat, so then I took it off and turns out it is functioning properly, so heater valves back on and open. Is there a flap or something in the dash that the **** turns to change from hot air to cold air as well as move the cable? That's the only thing I can think of. Do I then have to take the dash apart to fix it. I need to fix this quick before it gets cold again. Thanks.
Old Jan 26, 2018 | 09:17 PM
Check that the **** you turn didn't crack.
I think the cable from the heat **** controls the coolant valve in the engine bay and also the air mix door. The common diy thread on top of the gen tech forum has a link to online shop manuals. The hondahookup site has a 94 shop manual you can download. The heater unit is the same as your 97 accord.
Old Jan 26, 2018 | 09:32 PM
Oh. So the heater **** controls a door? That's gotta be it because the heater valve is working. Thanks! So I'm guessing gotta pull the dash apart?
Old Jan 27, 2018 | 07:30 AM
The **** I was talking about is the one you turn with your hand to adjust the heat. The **** just pulls off. It is not uncommon for them to crack. It is a quick and simple test.
If that **** is ok, then you will have to get into the dash and look at the attachment points of the cable that is adjusted by the heater control.
Old Jan 29, 2018 | 10:03 AM
TexomaAccord's Avatar
from the passenger side floor board, pull the carpet back by the console, there is a blend door there (on mine there is)
skijour
Aug 15, 2012 08:31 PM
Cessna172
Nov 5, 2010 01:22 PM
mamtsberg
Sep 21, 2009 06:53 AM
vince_carnovale
Jul 18, 2008 07:38 PM
misterluh
Dec 3, 2005 11:02 PM
