91 accord start issue
Old Jul 12, 2009 | 06:54 PM
starrett59's Avatar
Default 91 accord start issue
Car sometimes won't start as if out of gas or spark. 50 amp. boost charge will start car, jump start won't. Jump start did not work today but an hour later car started when I turned the key, Any ideas what to check, Battery and Alt. good. Greatful for any ideas.
Old Jul 13, 2009 | 10:25 AM
Welcome!
This area is for website questions, so I'll move this to General Tech where you're more likely to get an answer.
Check BOTH ends of all battery cables. Sometimes they can be corroded or loose at the other end from the battery, & that can cause problems.
Old Jul 13, 2009 | 05:19 PM
hondadude's Avatar
This Could be a main relay problem.
The typical scene is that the car will start in the morning but not after sitting in the sun all day. Hot interior/no start..............Cool interior/YES start.
You can pop the guts out of the relay housing up under the dash, and resolder the relay coil joints on the circuit board.
Beyond that diagnostic, it is best to find out if you are losing spark or fuel pressure.
You should be able to hear the fuel pump run up presssure for 3 seconds when the key is turned on.
Spark check by using an old spark plug to see if there is spark going out to the cylinders.
Tony1M
Nov 6, 2023 08:29 PM
tzoromski1
Oct 4, 2012 10:24 PM
Cubeman
Jul 23, 2012 12:40 PM
zZHellBlazerZz
Jun 15, 2011 10:12 AM
art vandelay
Aug 2, 2010 09:29 AM
