91 accord starting issues??
Old Aug 2, 2012 | 06:15 PM
Jacob Steele's Avatar
Default 91 accord starting issues??
i have a 91 accord that had a F22A4 and i replaced the engine with a F22A1 they both ran before i swapped them now after i put the replacement engine in F22A1 i have no spark i replaced the rotor button the cap and plugs and wires after i did that without messing with anything else the starter wont work with the key so now im thinking electrical problem but i went all through the fuse box and wires i have no idea wat to do now plz help someone??
Old Aug 2, 2012 | 06:55 PM
Silver6gen's Avatar
coil or icm? have you checked those?
Old Aug 2, 2012 | 08:12 PM
yes i have two dizzys both test good as well as there internal coils but im new to hondas so where is the ICM??
Old Aug 3, 2012 | 06:19 AM
my1st.honda93's Avatar
could be your main relay?driver side under the dash
Old Aug 3, 2012 | 07:24 AM
To answer your question...
ICM = ignition control module = slang term is "ignitor".
It's inside the distributor; it's kind of an isolation amplifier to prevent voltage spikes from the coil from getting back to fry your ECU.
Old Aug 3, 2012 | 09:18 PM
And to add....check that the main ground - G101 - is attached/clean and tight. This ground is on the "lower" bolt of the t-stat housing for your 4th gen.
mjb
Oct 15, 2009 06:26 PM
justincollier
Sep 11, 2008 09:33 AM
cumminsman
Feb 13, 2008 12:09 PM
Slowaccord
Aug 28, 2007 08:38 AM
MRMASON
Oct 3, 2006 07:09 PM
