'91 Accord wiper motor
Where can I find a good source for a schematic for replacing the wiper motor. My wipers quit working and am not sure where the relay is to replace if needed either. Could sure use some help...Thanks!
Hey. For fuses and relays, there are 2 boxes. 1 is somewhere under your steering wheel, and the other is under the hood neer the passenger side.
I think the fuse you need will be located in your box under the steering wheel/dash. I would try checking the fuse before getting a new motor or used motor from a junkyard.
