91 Power Steering Overflowing & Gurgling
Old Aug 6, 2011 | 03:01 PM
oneloudskunk's Avatar
Default 91 Power Steering Overflowing & Gurgling
My '91 EX Coupe has power steering fluid overflowing from the reservoir and it gurgles rather loudly. I've tried bleeding the system by turning the wheel lock-to-lock multiple times, but no improvements. It continues to gurgle and belch violently. There's no improper noises coming from the pump, just the gurgling from the reservoir. Any ideas?
Thanks,
-rob
Old Aug 6, 2011 | 03:08 PM
Air is likely getting pulled into the system. It could be a leak in the hose, or possibly the PS pump. Is there any fluid leaking?
Old Aug 6, 2011 | 07:13 PM
The only place fluid is leaking is the overflow from the reservoir.
Old Aug 6, 2011 | 07:45 PM
The only place w/ enough negative pressure to pull air in is the suction hose at the pump. Check clamp and hose for damage.
TexomaAccord
Apr 27, 2014 05:47 AM
Donda
May 10, 2013 12:11 PM
nickmg555
May 9, 2013 05:36 PM
jill hughes
Apr 3, 2011 08:34 PM
fireballer44
Jan 24, 2007 04:12 AM
