92 accord flex pipe leak
Old Jan 11, 2009 | 08:41 AM
kylemiller123's Avatar
Default 92 accord flex pipe leak
I have a 92 accord with a leak in the exhaust flex pipe. Does anyone have anytips on how i can fix the leak for a week or two until i buy a new one???
Old Jan 11, 2009 | 02:21 PM
Default RE: 92 accord flex pipe leak
There is a "muffler repair tape" available at auto parts stores that might do a serviceable fix for a few weeks.
Another option is tightly wrapped heavy thickness aluminum foil (or adhesive backed aluminum wrap from home depot, et al) , covered w/ thin aluminum sheeting and held in place w/ large worm gear clamps. It may be tough to get a tight seal, so perhaps use some HT RTV to first seal the holes before wrapping. Temperatureof flex joint will damage most putty.
I've sealed an exhaust pipe w/ just a wrap of sheet metal tightly clamped w/ worm-gear clamps, but rough surface of flex joint may not work w/ just a metal sheet.
Old Jan 11, 2009 | 08:12 PM
My father would remove both ends off of a soup can to have an open cylinder. He would cut the cylinder down one side, and use that along with two hose clamps as a temporary fix.
cavemantitan
Jun 5, 2013 12:19 AM
dunnskii
Aug 10, 2010 04:49 PM
Jmoney
Jun 12, 2009 09:37 PM
manah
Sep 17, 2007 12:14 AM
hwtap
Jul 11, 2006 04:30 PM
