92 accord no 5th gear
Old Nov 23, 2016 | 12:32 PM
zedjr's Avatar
Default 92 accord no 5th gear
I have a 1992 accord ex 5 speed. 5th gear when out when driving on freeway. It just revs with no engagement. No grinding or anything like that. Just no 5th gear. The shifter will go into 5th fine just there is no engagement when clutch pedal is released. All other gears work fine. Is 5th gear easy to replace like some previous models? Any help is appreciated. Thanks
Old Nov 24, 2016 | 09:41 AM
If you want to rip into the trans, yea not that bad of a job.
Another option is to get another from a bone yard. From there either just swap that in as is, replace the fluid and since you are there, the clutch "job" as well. Or rebuild the one from the bone yard and then put it in.
Old Nov 24, 2016 | 07:41 PM
zedjr's Avatar
Yes i know this. That is not what i asked though. Is 5th gear easy to replace like some previous models?
Old Nov 25, 2016 | 05:13 AM
Previous models of Accords? The manual trans from any F series engine (90-02) are almost identical so in that case - YES.
93Accord2.2
Aug 5, 2013 06:38 PM
vral81
Mar 6, 2012 01:28 PM
BigShelby
Apr 7, 2009 05:26 PM
llmwall
Jan 12, 2008 10:38 PM
88accord
Nov 10, 2007 09:01 AM
