92 Accord oil leak not pressure switch. Maybe oil cooler?
Old Nov 29, 2015 | 07:19 AM
Jak3l's Avatar
Default 92 Accord oil leak not pressure switch. Maybe oil cooler?
Alright guys got an oil leak that's pissing on my exhaust and I replaced the pressure switch a couple months ago so this is a new one. I'm thinking maybe oil cooler but I'd like all suggestions to look over all possibilities. It's definitely coming from or above my filter area cause I can see it dripping off of it. I replaced the filter and oil pressure switch just to be safe. What are you guys thinking? 92 Accord EX 307,000 and counting!
Old Nov 29, 2015 | 01:55 PM
There's 2 plug/bolts on the back of the engine block, above the oil filter. One is coolant, one should be oil. Can you get a good look (from underneath?) to convince yourself whether that's leaking? Clean it good then wait for it to leak some more? I'd want to be sure before I opened anything up.
Sticking out from the oil cooler is the pipe nipple that the filter screws onto. THAT goes clear thru the cooler & holds the cooler onto the block. Look for a relatively large hex to put a wrench on that thing. Then there's an O-ring between the cooler & the block.
Attached Thumbnails 92 Accord oil leak not pressure switch. Maybe oil cooler?-1992-oil-pump.gif
hepta
May 8, 2015 05:56 PM
B501
May 27, 2012 08:28 PM
pirulino23
Nov 12, 2011 06:34 PM
ChicagoBob123
Nov 6, 2011 06:22 PM
swells244
Jul 9, 2010 08:28 PM
