92 accord starting problem
Old Sep 28, 2007 | 08:39 PM
gaugeman's Avatar
Default 92 accord starting problem
My 92 LX 5 speed has an intermittant starting problem. Once in a while it fails to start. You can come back later (minutes or hours) and it will start immediately. Once started everthing works normally and it will re-start after being turned off. I have changed plugs and ECU andchecked other ignition and fuel components. There are no ECU codes.
Does this sound familiar to anyone. Anybody have any ideas?
Old Sep 28, 2007 | 09:06 PM
Default RE: 92 accord starting problem
Do a search for Main Fuel Relay. This is a constant source of failure to start problems for Hondas of all models and years as they share the same relay. Wonder why Honda doesn't try a different brand of relay besides Mitsuba?
Check the DiY section for tips.
Old Sep 29, 2007 | 03:54 AM
2POINTautO's Avatar
The number one problem with the main relay is loss of fuel pressure (pump), there are two relays built in the assy, one is for the fuel pump and it goes bad when the inside of the car is too hot, its really bad when the inside of the car is just warm, it almost never goes bad in the winter time. Not all Honda use the same part number so make sure you get the correct part when you pick one up.
Crack open the 12mm bolt on top of the fuel filter, no start on the engine and you will not get a good flow of fuel from this loosened bolt, bad relay. Under dash near steering column, hidding behind cruise control computer if you have one, look at new one to see what it looks like before tearing everything apart. Remove guts from outer grey housing to swap it out, no need to unbolt everything.
If this is not it then give better details.
Old Sep 29, 2007 | 05:30 AM
gaugeman's Avatar
I will check out the relay. The temperature thing makes sense since the problem started this summer. Could be a simple fix to a problem that's been driving me crazy.
Old Sep 29, 2007 | 10:11 AM
deserthonda's Avatar
go to our DIY section there are write ups on main relay location and how to repair it ,,or replace it if so you choose
Old Sep 29, 2007 | 12:47 PM
gaugeman's Avatar
I'd like to thank all those who responded. I bought a new relay module & replaced it and hopefully thats the end of it. The relay is way up under the dash and awkward to get to. It's located under the cruise control module (which must be removed)and it's not easy for a large person (like me) to get to.
Old Sep 29, 2007 | 01:42 PM
2POINTautO's Avatar
Thanks for posting your FIX, its nice to know when we guess correctly.
Old Sep 29, 2007 | 03:36 PM
ORIGINAL: 2POINTautO
X 2
Yamasaki
Nov 5, 2011 09:19 AM
quack31
Feb 5, 2007 05:07 AM
babylon888
Feb 16, 2006 02:08 PM
cyurgeles
Jan 21, 2006 10:36 AM
rev2ninetyper
Nov 14, 2005 04:06 PM
