'92 Accord, TCU problems, D4 light stuck on
Old Oct 12, 2012 | 03:52 PM
kerrn's Avatar
Default '92 Accord, TCU problems, D4 light stuck on
The D4 light is on all the time. I've been reading about TCUs and I've got mine out of the car to inspect it. Found 2 caps and 1 resistor burnt out. I replaced those along with all the other electrolytic capacitors and put it back on the car. It didn't make a difference. Then I checked a bunch of resistors and diodes from around the burnt caps. Reheated some solder joints, checked the connectors, the grounding. All looks fine. But the light is still on and the car is sluggish. Then I checked the solenoid connectors, the ground wires under the hood, the fuses (Is there a fuse for the TCU somewhere? I couldn't find it.) I found that some wires (from the ECU/TCU connectors) had the insulation chewed off by rodents (but they weren't shorting) and I masked those with electrical tape. I want to test the wires with a multimeter but I can't find a diagram anywhere. All I could check was the black (ground) wire.
The TCU is a 28100-PXO-A21-M1 (PXO or PX0?) and I couldn't find one like it for sale. On the other hand I'd rather DIY this because I'm short on cash after fixing a bunch of other things on this car.
Any tips, any ideas? What should I do next?
Old Oct 12, 2012 | 06:34 PM
I have found the cross reference to car-part.com to work well. It will show donor vehicle to yours.
Also check ebay sellers who show cross reference TCU's. For example:
90 91 92 93 HONDA ACCORD TRANSMISSION ECM COMPUTER TCU REPAIR REBUILD SERVICE | eBay
dlb
May 22, 2012 09:54 PM
Mad Lion
Sep 16, 2011 07:31 PM
runner080290
Aug 28, 2011 06:50 AM
jedds92
Dec 1, 2007 12:13 AM
kornfox
Mar 29, 2007 10:48 PM
