92, replaced oilpan gasket, accord
Old Jan 6, 2010 | 09:20 PM
Jeff1966's Avatar
Default 92, replaced oilpan gasket, accord
appears to be front seal. How difficult is this to replace?
Old Jan 7, 2010 | 02:17 PM
Which seal are you talking about? One of the four under the timing belt or the main seal behind the flywheel?
Old Jan 7, 2010 | 02:49 PM
Jeff1966's Avatar
I have been focusing on the lowest one behind the balancer. Mechanic just put timing belt and water pump on. Kinda mad cause he didnt go ahead with seals while he had it on the rack. So I pulled of all the belts and put electric impact wrench on bolt with no luck. I was going to remove balancer or pulley to see for sure it is front main lower.
Old Jan 7, 2010 | 03:52 PM
kris_loehr's Avatar
It could be the balancer shaft seal.They tend to come out of the bore and Honda has a retainer to stop that. It would look like the crank seal leak until you take the timing cover off. Crank seal, cam seal or balancer shaft seal are going to be about the same as doing the Timing belt job.
Old Jan 7, 2010 | 08:30 PM
Jeff1966's Avatar
Default balancer shaft and crank shaft seal is this two different or the same
what are the four seals behind timing cover?
Old Jan 7, 2010 | 08:35 PM
Jeff1966's Avatar
Default 218 k need to replace all seals
I need to remove timing cover and pulley or balancer to see where leak is coming from
Old Jan 7, 2010 | 10:23 PM
kris_loehr's Avatar
You have a seal for the crank shaft which is behind the pulley at the bottom. At the top is a cam seal. Four cylinder engines over a certain size have a counter balance shaft such as your 2.2. It is in the middle left and is run by a second belt. On my 1995, Honda had a recall to replace the counter balance seal as they were coming out of the bore. They installed a retainer to keep it in. I believe on your 92 a retainer should be added if you replace the seal. It is a half moon bracket which I believe uses a bolt hole that is already on your engine. There is a tool that you use to hold the crank pulley from turning while removing the crank bolt.
Old Jan 8, 2010 | 06:56 AM
Jeff1966's Avatar
Default Thanks for the information
Chris This is very helpful. Have a great day Jeff
gitch414
Jul 29, 2014 04:55 PM
cjkone978
Jun 30, 2011 08:08 PM
chevmechanic
Apr 10, 2011 09:31 AM
jackfast
May 15, 2010 09:16 PM
MichaelT1960
May 9, 2010 02:00 PM
