'92 Speedometer problem
Old Sep 10, 2009 | 06:03 PM
disramirez
Default '92 Speedometer problem
I have already replaced the speedsensor on the car, and that is not the problem. Since I have already replaced the sensor, what is the next that I need to checked.
Old Sep 11, 2009 | 06:39 AM
Welcome!
Does your check-engine light come on?
If the speed sensor were bad, the check-engine light would come on. If it didn't, then it's probably a bad speedometer (in the cluster), or maybe the wiring connections that plug into the cluster.
Old Sep 11, 2009 | 10:56 AM
disramirez
Yes after a few minutes the light does come on. Also, a quick history, I originally replaced the sensor last November. It worked until about Jan or Feb of this year, then it stopped again, I replaced the sensor and it still didn't work. The problem code that the computer says is the speedsensor.
Old Sep 14, 2009 | 07:12 AM
The computer can't tell the difference between a bad sensor vs. bad wiring for the sensor. Since a new sensor didn't really fix it, maybe it's a wiring problem.
Easy stuff would be corroded or loose wiring plugs down there by the sensor? For 92 I'm not sure where else in the harness that circuit goes through any other plugs. Finally (and more difficult to find) the wiring could be broken anywhere along the harness.
pyramidhead
Apr 17, 2009 12:11 AM
ughcord
Oct 15, 2008 11:32 PM
abhijitgp
Oct 4, 2008 11:32 AM
abhijitgp
Sep 27, 2008 12:55 PM
james.walters
Mar 13, 2007 04:43 PM
