92 valve cover replacement
Old Oct 19, 2008 | 08:42 AM
partsman1's Avatar
Default 92 valve cover replacement
I getting ready to do a valve cover gasket on my 92 Accord. I found oil in my spark plug wires. As I do this repair, does anyone know if i should use some rtv when doing this. I asked one of the techs at my work, ( BMW tech) and he said to use it on the corners or any uneven serfice. If there is someone that might know some tricks for this job, please let me know them. Like, should i use rtv on the spark plug gaskets? And is there anything else i should do while doing the job? I never had to do a valve cover gasket on any Honda that I have owend. And I have owned quite a few Accords. Only older ones.
Thanks again
Old Oct 19, 2008 | 11:09 AM
Default RE: 92 valve cover replacement
A little RTV at the 4-corners where gasket crosses the camshaft bearing assy.
No RTV on spark plug tube gaskets, but be sure they're installed correctly. Some have an open side that must slide down the tube as you install. The open side should allow seal to slide easily along the tube. If reversed they won't seal. I'm pretty sure the correct direction is open side facing into the valve cover groove. But look at your arrangement and be sure. It's obvious after stopping and considering.
Don't overtighten the hold down bolts. I think torque is 7 ft-lbs.
Old Oct 19, 2008 | 06:17 PM
hondadude's Avatar
Old Oct 20, 2008 | 12:58 PM
Permatex Grey is a good substitute for HondaBond. Just a little bitat the sharp corners.
I think theres another set of seals further down in the spark plug tubes. For those, you have to remove the rockers &camshaft bearing caps, so its a bigger job. Hope it stops leaking when you put in the new VC gasket.
MCCurtis
Mar 2, 2015 06:14 PM
JimTrail
May 21, 2012 09:12 PM
03Sleeper
Jun 11, 2008 08:54 PM
crvone
Dec 29, 2007 02:13 AM
lightshow
Jan 11, 2006 11:49 AM
