93 accord back firing when i am driving
Old Dec 3, 2011 | 11:45 AM
mcdonald109's Avatar
Default 93 accord back firing when i am driving
when i accelerating or around 2k rpm cruising my car back fires and skips. i replaced plugs, fuel filter, and cleaned my entire fuel system and nothing seams to work. also very hard to start when warm. what could be wrong?
Old Dec 3, 2011 | 11:54 AM
Are there any stored codes?
Cap/rotor/wires check out fine?
Next on the list, don't ge there yet until we do some more testing, clogged egr ports. Not just the valve but the actual ports on the intake runners....93 has the "plugs" that have to be pulled.
Old Dec 3, 2011 | 12:06 PM
I changed the cap, button, coil, and timing belt last month. i was going to change the wires today. i have yet to try to find any codes.
Old Dec 3, 2011 | 12:24 PM
Ok, didn't see them listed...Test the wires instead of spending money on something that may not be needed...after the t-belt change it was fine...correct? Have you re-checked the timing marks?
Old Dec 3, 2011 | 02:16 PM
Yeah it worked fine after the t-belt was changed. it started like 2weeks after.
i will check the plug wires.
it only does it when im only 1/4 throttle if i push it to the floor it doesnt do it at all. i have a 5spd
Old Dec 3, 2011 | 05:31 PM
Sounding more and more like the egr ports......
Old Dec 5, 2011 | 11:27 AM
ok so i found out what it was,
the main wire going to the coil got a hole burned in it and the wire was frayed. it was sparking against a metal hose under the hood and not getting proper spark through the coil. which caused too much fuel to get in the engine and flood the engine and foul the plugs. I cut the wire behind the hole and shaved the wire and put it back in the coil properly and it works fine.
it was something so simple that cost so much time and unneeded parts but its fixed
losthondaguy
Jan 25, 2012 03:23 PM
viper6
Dec 3, 2011 12:33 PM
teamBOMB
Jul 24, 2011 03:44 PM
jthompson055
Jun 3, 2011 01:40 PM
wildwildoates
Apr 13, 2011 07:38 AM
