93 accord engine blow?
Old Feb 19, 2013 | 02:15 PM
Hamster108's Avatar
I am interested to see what you find when you pull the head
Old Feb 19, 2013 | 04:36 PM
UhOh's Avatar
The photo of the spark plug is great = beyond my experience.
Old Feb 19, 2013 | 04:58 PM
shipo's Avatar
Those spark plugs look like your engine was suffering from pre-ignition; a very rare but highly damaging condition which typically puts the engine beyond repair within a second or two. If I'm correct then the engine has most likely suffered one of the following failures (ordered from highly-likely to less-likely):
  • One or more pistons with holes in them
  • One or more valves bent or burned away
  • One or more bent connecting rods
  • Damage to the valve lifters
  • Broken or damaged cam shaft(s)
I agree with Hamster108, I want to see what is revealed when you pull the head.
The above said, were I in your shoes (and time was tight) I wouldn't bother with the head; I'd find a used or rebuilt motor and swap the engine. Long story short, your engine is (most likely) toast.
Raf_flores
Mar 7, 2014 10:00 AM
Loren32
Dec 22, 2013 07:09 AM
himey29
Aug 4, 2010 05:04 PM
skowald
Nov 15, 2007 04:57 PM
SpentNed
Apr 28, 2007 11:40 PM
