93 Accord LX CEL and D4
Old Nov 2, 2012 | 06:29 PM
cmerlin7373's Avatar
Default 93 Accord LX CEL and D4
I have a 93 Accord LX I recently picked up for my wife and it was in a minor accident. The only damage was to the grill, hood, upper rad support and rad. I got replacement parts from the local jy but im having a prob w the cel and d4 flashing. I looked up how to check the fault codes on this site and got a 6 from the cel which is the ect sensor and a 10 from the d4 which is the same sensor. I have replaced the sensor and left the batt disconnected for hours but the darn cel and d4 keep popping up w the same code. I saw somewhere in my reading that this could be caused by air in the cooling system but i can't seem to fig out how to bleed the air or what else could be causing this. I'm beginning to wonder if I have cleared the codes from the ecu\tcu at all. Any help would be greatly appreciated!
Old Nov 2, 2012 | 06:45 PM
Do you have a part number for the sensor you replaced? How many wire were going that sensor?
Old Nov 2, 2012 | 07:19 PM
I don't have a part number. It's attatched to the thermostat cover. Is there another one? In my volvos there is one for the gauge and one for the ecu.
Old Nov 2, 2012 | 07:20 PM
sorry, one connector w 2 wires in it.
Old Nov 2, 2012 | 10:00 PM
The ECT sensor is in the side of the head, roughly under the distibutor. It has a 2-wire connector same as the one you replaced.
The one in the T-stat housing is the fan switch. Did you install a new ECT sensor into the fan-switch location? If so, put the old one back in, and install the ECT sensor into the head. Most likely you didn't mess anything up by instlling it to the wrong place.
The sender for the temperature gauge is also in the side of the head, but it's only got 1 wire. There's another fan switch at the UPPER radiator hose; that one only has authority after shutting off the engine.
At the T-stat housing there's a bleed valve, looks about like a brake bleeder. Set the interior temperature control all the way to HOT, to open the heater valve. Open the bleeder to allow air to bleed out. Top up at the radiator cap.
Old Nov 3, 2012 | 08:49 PM
Excellent info! Thanks JimBlake. Will do tomorrow and report back.
Old Nov 4, 2012 | 05:53 PM
I located the proper sensor and realized it wasn't connected at all. It seems the wires had gotten brittle, prob from all the heat there, and broken completely off. I went to the jy today and snagged a connector but haven't had a chance to install it yet due to the time change. I'll hook 'er up tomorrow and report back.
Old Nov 16, 2012 | 07:46 AM
update: all went well and no more cel! shes running well and getting us around like a champ. thanks for all your help!
Old Nov 16, 2012 | 01:35 PM
Good; thanks for coming back with the result.
NavyAg
Aug 21, 2012 10:18 AM
firefighter44
May 8, 2012 06:10 PM
Khai Son
Mar 14, 2012 11:32 PM
capthoward
Jun 25, 2011 07:25 AM
murphb00
Dec 16, 2010 08:40 PM
