93 Accord LX Noise
Old Nov 11, 2013 | 12:06 PM
coolestnerd's Avatar
Question 93 Accord LX Noise
This is driving me mad! LOL I have been trying to figure out what is causing this noise for weeks. I have a video of the noise.
Here
Old Nov 11, 2013 | 06:07 PM
So this only happens once the car is in closed loop.
Two guesses to start with, as there are no codes but please verify the CEL does "bulb check" when you turn the key to on....should come on for ~3 seconds and then go off.
EGR ports.....not just the valve but the ports in the intake manifold....could be clogged. Not a fun job on a 4th gen but can be done pretty easy.
Next, really a reach.....a lazy O2? How is the MPG on the car?
Old Nov 11, 2013 | 06:25 PM
Agree with Poorman, possibly EGR ports clogged. Although, your video doesn't fully show the tach's rpm when the noise occurs, it sounds like a hesitation or stumble at somewhat lower rpms.
There is a Honda TSB for your car regarding an engine hesitation or stumble can be felt under light acceleration between 1,500 and 2,000 rpm due to clogged EGR ports.
Honda TSB 98-074
Old Nov 20, 2013 | 02:37 PM
Update and better video for help in diagnosing.
Old Nov 20, 2013 | 02:48 PM
Cool tool.
Old Nov 20, 2013 | 03:13 PM
Cool tool.
Cool but I cannot figure out what is causing this noise. I have clamped the sensors to the block of the engine and the transmission and no noise from them. Definite head scratcher.
Old Nov 22, 2013 | 06:54 PM
When you say cross member....is the the one up front by the rad? Can we assume the front mount id ok?
Under hard braking....does the car seem to pull side to side.
stockxplorer
Sep 25, 2022 04:15 PM
clforever
Dec 4, 2008 09:21 AM
Jul 30, 2007 12:30 AM
atwood
May 1, 2006 08:59 PM
Gimly54
Feb 1, 2006 09:05 PM
