93 Accord- Oil leak
Old Apr 17, 2012 | 12:46 PM
fawatson3's Avatar
Wink 93 Accord- Oil leak
I have 93' Accord oil leak and need some help with directions on how to proceed with removing harmonic balencer?
Old Apr 18, 2012 | 06:49 PM
I moved this, didn't "fit" at the end of the thread you posted in.
Removing the crank bolt on one of these can be the most fun. Suggest you read up on changing the T-belt on one of these. IF the leak is coming from behind the cover you might as well do the job right, which would mean replacing the t-belt, wp, ect while there.
Not sure where exactly the oil is coming from on that end (pic would be nice), you might get lucky and it could be coming from the valve cover, where the gasket goes over the "cam hump".
Old Apr 19, 2012 | 01:26 AM
deserthonda's Avatar
those are notorious for the balancer shaft seal popping out and or leaking
if oil coming from inside t-belt cover ??
Old Apr 19, 2012 | 06:42 PM
Ahh, good to see you my friend
Yes....I was trying to give the op a bit of hope with the valve cover....if it is not coming from there, time to go in and I said, might as well do it all while you are there.
alltime3rdwheel
Dec 31, 2012 10:46 AM
frost506
Jan 16, 2012 07:21 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
mamtsberg
May 30, 2010 07:04 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
