93 EX Cutting out
Old Jun 18, 2015 | 05:11 PM
SlimGoaty's Avatar
Exclamation 93 EX Cutting out
So I've got a 93 EX 5spd 293k F22A6. About 2 months ago it started cutting out when driving if you didn't let it warm up, and only for about 10-15 minutes then it would clear right up. For the next month or so I would just let it warm up before I left and then it would be fine. When it cut out I could hear the main relay clicking, the CEL and Batt light would all come on. It would just cut out for a second and pick right back up, and not just like a single cylinder cut out, this was a very violent full engine cut out.
Fast forward about a month. Driving home one night it wouldn't stop cutting out and basically got to the point that I couldn't accelerate or keep speed. I could push in the clutch and the RPM would increase and slowly start to fall. It also smelled of raw fuel (seems like a spark issue, not fuel). The tach was jumping around +/- 5k RPM.
Battery checks out fine, Alternator checks out fine.
Symptoms are Cutting out but not dying completely (only once). Main Relay making a lot of noise, check engine light and battery light both come on, and tach jumping. It will idle just fine touch the gas and get the RPMS around 2k-2.5k and it starts going crazy.
Trying to figure this out without throwing a bunch of parts at it or taking it to a shop, its just a commuter and I didn't pay very much for it. Could it be the dizzy/Ignition module, Main Relay?
Old Jun 18, 2015 | 07:09 PM
Do some testing before replacing any parts.
1. Check for engine codes (see the common diy thread on top of the gen tech help forum).
2. When the engine is running, try shaking the key. Does that cause the engine to stall/cut out?
Drabix
Nov 30, 2009 07:04 AM
HondaGuy256
Mar 8, 2009 10:27 AM
moonlight03
Mar 18, 2008 01:36 PM
shostak
Feb 21, 2008 06:58 PM
wisey
Jan 24, 2008 07:02 PM
