93 Honda Accord EX no spark
Old Aug 8, 2009 | 06:26 PM
jenn.b.butler
Default 93 Honda Accord EX no spark
My car starts sometimes, doesn't start others, and sometimes will start and shut off while I'm driving. 3 mechanics said I'm not getting spark. I have new and working spark plugs, new ignitor and new ignition coil. The timing belt has good pressure. What could be the problem. No one seems to be able to figure it out to fix it.
Old Aug 8, 2009 | 08:11 PM
If timing is assumed to be OK, it could be fuel pressure is missing or spark is missing. This seems trivial observation, but is first step in solving your problem. You don't presently know which is missing.
Easiest check is to spray starter fluid or throttle body cleaner in the air intake at the air filter end, and attempt to start. Spray a good dose, 5-10 secs of continuous spray. If you get no temporary start or attempt to start, spark is indeed missing. If it starts briefly and runs, fuel pressure/delivery is the problem. Perform this test and report your results to get next step.
Old Aug 8, 2009 | 09:12 PM
jenn.b.butler
The relay system for the fuel is brand new as well.
Old Aug 9, 2009 | 02:51 AM
deserthonda's Avatar
go to DIY section page 2 no start o spark,,,,,,,coil or ignitor ,, follow the procedure there and let us know the results ,,,,,,,,,,chk engine lite on ??
sirtwist2
Sep 24, 2012 01:36 AM
SeanAccord
May 18, 2010 08:24 PM
Cleiver
Feb 21, 2010 07:45 PM
xadous
Feb 10, 2008 10:54 PM
Jeffmech
Sep 13, 2006 11:10 PM
