93 honda accord... help!! NEW MEMBER
Old Jun 15, 2012 | 08:52 AM
Jessica Lynn's Avatar
Exclamation 93 honda accord... help!! NEW MEMBER
hello all
i have a 93 honda accord with141,000 on it
i am told i will have to get an internat belt replaced at 160,000
i also need new tires...
how much is that going to run me?? is it worth it? should I trade it in?
Help!!
Old Jun 15, 2012 | 09:20 AM
That all depends on if your likeing your car.
It is worth it if you do.
If your a gal, have a man call around to 4 or 5 repair shops to check on prices because as we all know, they take advantage of people. That called an interferance belt I believe to be what you were refering to.
Also put in your engine size. Tires are just another shopping experience, do the same thing with the shopping..make sure you get the tire size off all 4 tires to make sure you have one size only.
Welcome to the HAF...
Old Jun 15, 2012 | 09:40 AM
It's a timing belt and if it breaks, it can damage the engine ($$$). Your Accord has what is called an interference engine. Here is a good explanation:
http://www.civicforums.com/forums/po...444-post9.html
The costs to replace a timing belt, water pump, and oil seals generally runs about $400 - $700. The water pump and certain oil seals are usually replaced at the same time, as access is there when removing the timing belt and if those fail later, you would roughly be paying for the same labor at least twice. If the water pump and oil seals are done at the time of the timing belt change, you are mainly paying for the parts of the water pump and oil seals and not much additional labor costs.
Old Jun 15, 2012 | 11:49 AM
Jet sitter's Avatar
141K miles on a '93 is very low mileage. The car is definately a keeper. I had my water pump and timing belt replaced on my 2000 Accord 4 cylinder at the Honda dealership for under $400. earlier this year. Tires are normal wear and tear. Go to tirerack.com and have them installed at WalMart.
Old Jun 15, 2012 | 02:36 PM
Honda 446's Avatar
yes, Timing Belt. I believe on those engines its recommended to replace the water pump at the same time. I've had a couple Accords that I put that $$ into and it almost paid for itself when I went to sell them. a VERY big selling point. tell a potential buyer that 'yes, I've had the Timing Belt replaced recently' and show them your bill.
my last Accord I had the belt replaced on, I had it done twice, once at 90K and again at 180K. sold it at 190,000 miles and the new owner was thrilled to death I had already done that 'for them'.
Old Jun 16, 2012 | 06:39 AM
my1st.honda93's Avatar
hi hun if i were u an if u luv ur honda as much as we luv ours then by all means spend the money to get done what needs to be done! i speak for myself,i do all the work on my car an my wifes car she drives the Lexus???neways i kno u cant DIY hun so u need to take it to get it done,so ask urself even if u trade it in for somthing else eventually that car will need work done to it in the future!take care of what u have an ur car will take care of u
Old Jun 16, 2012 | 08:35 AM
UhOh's Avatar
Originally Posted by Jessica Lynn
hello all
...?? is it worth it? should I trade it in?
Help!!
Will it last? Last fall a news item about a Maine insurance adjuster who ran his '93 Accord to one million miles;
Honda appreciated that so much that they gave him a new Accord.
My son's '93 has ~240,000 on it.
Bcleader
Oct 24, 2012 05:37 PM
2010couper
Jul 8, 2010 05:11 PM
mamtsberg
Mar 17, 2010 09:15 PM
tonytran
Aug 14, 2009 08:31 AM
kumazam
Mar 6, 2008 04:05 PM
