97 Accord blower position switch not working
Old Jun 15, 2012 | 08:22 PM
JasonSater's Avatar
Default 97 Accord blower position switch not working
So The heat/AC always blows through the vents and when i press the defrost or feet button, the lights change to that position but the air still comes out of the vents. I've tried looking for what could be wrong and cant find anything. any suggestions on what this might be?
97 Accord LX 2.2L 4cyl V-TEC MT
Old Jun 16, 2012 | 09:07 AM
This could be mode control motor or Fuse 8 (under dash). check fuse first.
If fuse is good (likely since mode selection lights work), then you'll need to run through the diagnostics to confirm mode control motor. See DIY forum, Online Manuals post and download the 94-97 Accord Manual. The AC/Heater section has the diagnostic flow chart. You will need a Volt-Ohm Meter (VOM) to perform the checks.
Manual will also guide replacement of mode control motor if necessary.
Pacman311
Sep 28, 2013 06:26 AM
rocus
Dec 11, 2012 05:24 PM
Honda Man For Life
Apr 9, 2012 09:38 AM
Austinl93
Dec 6, 2010 09:23 AM
tinku928
Oct 19, 2009 09:34 AM
