Sponsored by:
Sponsored by:
93 honda not cranking
Old 04-22-2011, 05:03 PM
tinkerevil's Avatar
Default 93 honda not cranking
I have a 93 Honda accord se...it was running fine then one day wouldn't crank changed the battery plugs wires dist cap and rotor plus main relay it crunk once smoked backfired and died. Took it to a mechanic he changed the distributor the plugs and wires again took off and cleaned the exhaust system says its getting gas and fire will turn over but not crank. He has given up. What could it possibly be?
Old 04-22-2011, 06:49 PM
tinkerevil's Avatar
Sorry posting from my cell its a 4 cyl 2.2L automatic
Old 04-22-2011, 07:01 PM
Different people use different terminology. When you turn the key to start the car, does the starter start spinning the engine? Or does nothing happen?
Old 04-22-2011, 07:09 PM
Occasionally, spark will be observed w/ a plug grounded to engine. However when under compression in cylinder, the spark is too weak to fire the spark plug. Try checking for spark w/ an inductive timing light hooked to any spark plug lead. If you don't get a flash on the timing light, no spark is occuring. Check this to be sure you're getting fire.
You should also check to make sure spark timing is ~ 15 deg BTDC. If mechanic installed your distributor backwards (unlikely but possible), engine will not run.
Check engine crankshaft to camshaft timing by turning engine to 0 TDC on crankshaft, pulling upper timing belt cover (valve cover must be lifted), and see if camshaft is aligned w/ TDC timing mark.
You should download a 90-93 manual to guide alignment of crankshaft and checking camshaft TDC marks.
Another good test is to turn keyswitch to On, and crack the fuel rail banjo bolt. You should get a strong spray of fuel (~40 psi pressur). If no spray or weak flow, the fuel pump is not working; main fuel relay or bad fuel pump.
You should also check engine cylinder compressions. Speck is 135-180 psi, w/ no more than 20 psi difference between cylinders.
If you have fuel, fire, compression, and engine timing the engine will run. One of those is missing.
Old 04-23-2011, 02:52 AM
tinkerevil's Avatar
When I turn the key the starter spins the engine...and we did the bolt to the fuel it is doing what it is supposed to..will check out the rest thanks
opaque
04-22-2013 12:17 AM
L2_DJ
02-15-2013 09:01 AM
hondachic
08-06-2012 11:40 AM
Lurch
12-07-2011 07:55 AM
5.0stang
07-23-2009 07:24 PM
Quick Reply: 93 honda not cranking
