93 Turn Signal Problems
I have a 93 Accord EX that has a strange problem. The passenger side turn signal is flashing fast like a bad bulb. I have check the bulb and they are all good. The bumpers bulb is flashing fast. The side maker, rear signal, and instrument panel is not lighting up. But when you push the hazards they all light up. I have also check the switch in the steering column and its fine. The relays seems fine because the hazards work. Thanks for your help.
Bobdurfob
Apr 18, 2021 12:03 PM
