93 Turn Signal Problems
Old Nov 16, 2014 | 03:45 PM
BJO's Avatar
BJO
Default 93 Turn Signal Problems
I have a 93 Accord EX that has a strange problem. The passenger side turn signal is flashing fast like a bad bulb. I have check the bulb and they are all good. The bumpers bulb is flashing fast. The side maker, rear signal, and instrument panel is not lighting up. But when you push the hazards they all light up. I have also check the switch in the steering column and its fine. The relays seems fine because the hazards work. Thanks for your help.
Old Nov 16, 2014 | 03:53 PM
woody31's Avatar
Almost A Senior Member
Check your ground wires at the rear of the car. And welcome to HAF.
Old Nov 16, 2014 | 04:01 PM
BJO's Avatar
BJO
Thanks. I don't seem to be getting 12 volts at the socket.
Old Nov 16, 2014 | 04:22 PM
woody31's Avatar
Hmmm, not good, look for the harness and trace it back, I know that is not what you wanted to read but is all I have to offer, hope someone will chime in also with a lil better insight. Good luck.
Old Nov 16, 2014 | 04:29 PM
BJO's Avatar
BJO
Your right that is not what I wanted to hear. Thanks. You would think that a wiring harness problem would not let the hazards work correctly.
Old Nov 16, 2014 | 04:34 PM
woody31's Avatar
On my 96 the blinkers run thru the hazard switch, not sure on your car, and yes a harness issue would be a issue, i think the wires run form left to right at the rear but am not 100% sure.
Bobdurfob
Apr 18, 2021 12:03 PM
ransrobs
Jan 12, 2015 08:01 AM
aghigig
Nov 20, 2005 03:04 AM
jcvlz
Aug 24, 2005 11:34 AM
mega502
Mar 19, 2005 12:30 PM
