94 Accord Auto trans hard shifting
Old Aug 5, 2011 | 02:23 AM
sir_nasty's Avatar
Flushes on this year are sketchy at best drain and fills are the ticket... Also, some people seem to think that synthetic oil is kosher In the tranny" what does the fluid lok like?
Old Aug 5, 2011 | 10:31 AM
tashier's Avatar
Originally Posted by g22cd5
staple won't work bro. need to use a paper clip
It should, it's conductive. I just tested one.
Old Aug 5, 2011 | 10:32 AM
tashier's Avatar
Originally Posted by PAhonda
If no codes are stored, the check engine light will turn on and not blink if you properly shorted that connector.
Most of what I have read says to use Honda ATF. In my 95 shop manual it says to use Honda ATF or and equivalent Dextron2 ATF.
That's what I observed. CEL stayed on.
Old Aug 5, 2011 | 10:35 AM
tashier's Avatar
Drain and fills are what I planned to do. I have my first 4 qts of DW1. The fluid looked clean on the dipstick to me but the history of the car is unknown.
Old Aug 6, 2011 | 02:20 AM
tashier's Avatar
I did one drain and fill tonight, drove it around for a while through all gears, then another drain and fill. It was actually a lot dirtier and older than I thought. It is now shifting way better and what I'd call probably normal. I have enough oil for another d&f so maybe in a few days or so.
Anyone know why old oil makes it shift hard?
Old Aug 6, 2011 | 10:23 AM
IMO-I bet it was changed with DEX fluid, seen before where someone used it had the same issue, changed to Honda fluid and things got better.
Old Nov 1, 2011 | 10:46 AM
  #17
tashier's Avatar
Seems like it's shifting hard again. I wonder if the old oil in the torque converter has now made it's way around the tranny again. I'm thinking another flush?
Old Nov 1, 2011 | 11:05 AM
  #18
Unfortunately, changing the fluid is about the only maintenance you can do on the transmission. You can pull the shift and lockup solenoids and clean the screens and solenoids with some throttle body cleaner. Readjust that cable.
The other thing you may want to try is cleaning out the throttle body and the EGR ports. This helped my engine run much smoother on my 95 manual accord. Maybe this will help shifting?
Old Nov 1, 2011 | 12:11 PM
  #19
Fluid cycling is pretty fast. You can empty entire transmission volume in perhaps 1-2 mins at idle.
See "10 min atomatic fluid flush" on youtube for how to swap entire fluid volume easily.
Old Nov 1, 2011 | 12:25 PM
  #20
tashier's Avatar
Hey, that's a great video. Wish I would have known that before I bought 8 quarts of spendy Honda fluid.
Here it is:
10 Min Atomatic Transmission Fluid Flush + Replacement (Most Cars) - YouTube
M-train
Jul 11, 2023 06:34 AM
Rilex
Sep 13, 2013 07:35 PM
01f20accord
Aug 31, 2013 05:43 PM
vincentgould
May 20, 2011 12:17 PM
bmarshall
Jan 3, 2007 08:54 PM
