94 accord d4 light is blinkin and the car would go slow wen accelarating
Old Jan 1, 2008 | 09:13 PM
jose310's Avatar
Default RE: 94 accord d4 light is blinkin and the car would go slow wen accelarating
yeah im going to have it checked tomorrow, do you guys think autozone can check the tcu?
Old Jan 1, 2008 | 10:26 PM
HondatechAV6's Avatar
no, we already told you, you have to short the scs connector to flash the code.
Old Jan 1, 2008 | 10:27 PM
They can't check your TCU. The 94 accord is obdI and isn't the standardized OBDII that came out in the 96 accords. Shorting that service connector is how you check the TCU. Just stick the paperclip in there and turn the key to the II postition (don't start the car though)
Old Jan 2, 2008 | 12:53 PM
falkore24's Avatar
Hang on guys!!!!! He just had a dead battery!!!! Sometimes the computers get screwed up when the electrical system fails. If the problem was only that the terminals weren't making good contact, fix them or replace them .... also test the battery. Still it's a good idea to get the codes read, but I don't think there is any REAL problem here. If there are indicator lights or any kind of bad behavior after the battery is fixed for a few days, then I'd be concerned..... not concerned yet.
Old Jan 2, 2008 | 11:42 PM
jose310's Avatar
ok today i did the the tcu test, and i didnt get any codes, i changed my motor mounts and the car runs much better and the d4 light hasent came back on, i also did the ecu and i got 7 flashes which is throttle sensor, do you guys think thats was causing my surging idle?
Old Jan 4, 2008 | 04:01 PM
jose310's Avatar
ANY IDEAS?
Old Jan 4, 2008 | 04:08 PM
  #17
sir_nasty's Avatar
there are a lot of things that can cause a surging idle and a bad throttle sensor isn't going to help matters, it could have been doing any variety of things depending on what type of faliure it had....
Old Jan 4, 2008 | 04:17 PM
  #18
jose310's Avatar
how about my tranny problem?
Old Jan 4, 2008 | 04:20 PM
  #19
sir_nasty's Avatar
ORIGINAL: jose310
From the sounds of this post your tranny issue is gone for now.... did I miss read that?
wisertime
Sep 5, 2010 10:18 PM
mr92378
Jan 26, 2008 11:49 AM
jose310
Dec 21, 2007 08:28 AM
tran89
Dec 29, 2006 02:05 PM
sexybeast06
Jan 3, 2006 12:04 PM
