94 accord electrical problem
Old Jun 16, 2009 | 10:29 PM
fploof
Default 94 accord electrical problem
The radio was stolen from my 94 accord and they also punched the ignition to start it.
Now the turn signals and sun roof don't work!!
I checked all fuses and were ok...........also checked for cut wires and there were none...
Any ideas where the problem might be?
tx, frank
Old Jun 16, 2009 | 11:21 PM
That is a tough one. Do the hazard lights work?
Get a hold of a volt meter. You will be testing for voltage, so the red probe goes on the wire color, and the black will touch a good body ground. There is a grounding bolt under your center console (G404 in the pic I posted).
I don't want to sound condescending, but I just want to make sure that you test for voltage properly.
I would start with the turn signals, because they are more important. All the turn signal wires run through the hazard switch. That is the easiest place to start.
Pry out the hazard switch on the center console using a thin flat screwdriver, then unplug it.
When the key is turned to the II position (normal running position), both the yel/wht (it may be just yellow) and the wht/grn wires should have 12V. Let us know if you have voltage on those wires.
Old Jun 16, 2009 | 11:30 PM
fploof
This is my son's car so not that familiar with but I was looking for hazard switch and didn't find!! Is it in the radio counsel? If so, they took that too!!
Old Jun 16, 2009 | 11:46 PM
Its above and to the left of the radio.
Red triangle in the ebay pic. If that switch is gone, then that explains why the turn signals do not work.
http://tinyurl.com/nwecxp
TRIGGA
Oct 19, 2007 01:57 PM
roadman1977
Dec 30, 2006 04:37 PM
SnowDog1026
Dec 26, 2006 01:16 PM
eddyfurukawa
Feb 13, 2006 03:15 PM
qbtarget
Feb 13, 2006 01:56 PM
