94 Accord EX clutch problems
Old Dec 25, 2011 | 04:28 PM
FloridaRandy's Avatar
Default 94 Accord EX clutch problems
I've read several of the threads about the same problem I'm having, but I have a question before I try something else. I recently bought a 94 Accord Ex with 183,000 miles from a friend. The clutch started acting up on my 7 mile drive home where the top half had no pressure. I checked it out when I got home and found the reservoir was empty and when I checked behind the rubber boot on the slave cylinder I found the leak. I replaced it and tried to bleed the system by pumping the clutch pedal but it goes to the floor and will only return when I pull it back. Did some research and did a gravity bleed and then pumped the slave cylinder for a while. No air bubbles showed in the reservoir so thought I was good...but still no pressure on the pedal. No leaks that I can see. What now? Can the master cylinder be bad without leaking?
Thanks, Randy
94 Honda Accord Ex 2Dr, manual
Old Dec 25, 2011 | 05:26 PM
Search v=c-m5F0zEvyo on YouTube. It is a video on how to install and bleed the clutch master/slave cylinder.
Old Dec 26, 2011 | 03:32 PM
Thanks so much!! That method worked. I felt some pressure a short time after the fluid dropped and checked it and it's all good. Saved me from taking my full size truck on a trip...which saves me some gas money!
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
KimberlyC
Apr 16, 2006 11:51 AM
