94 Accord EX rod knock?
Old May 30, 2007 | 08:37 AM
Drpepper's Avatar
Default 94 Accord EX rod knock?
I recently had the oil changed in my Accord. I'm not sure what weight/type of oil the PO used but the shop I went to added 5W30.
I don't know if the oil weight is related but the engine has a pretty loud "knock" sound now.
Any suggestions on correcting that or do I need to start looking at a new engine?
Old May 30, 2007 | 09:15 AM
00AccordLX5spd's Avatar
Registered User
Default RE: 94 Accord EX rod knock?
Did they fill the oil to the correct level? Check the oil level. You want to make sure the shop didn't screw up andforget toadd enough oil back to your engine.
Old May 30, 2007 | 11:46 AM
Drpepper's Avatar
I always check the oil before leaving the shop, it was good.
I just went out to check the oil...just in case, it's good.
The valves do make a continuous "ticking" noise. Those are adjusteable, right?
Old May 30, 2007 | 12:05 PM
sir_nasty's Avatar
they are adjustable and it's not to hard to do. Go to our DIY section and there is a full detailed write-up on it.
Old May 30, 2007 | 02:04 PM
YeuEmMaiMai's Avatar
some cars like my 94 will always tick due to excessive wear on cam journal.....not a problem but it sounds like a sewing machine
fusionstar
May 7, 2009 08:18 AM
4cyl651
Sep 26, 2008 09:23 AM
19Accord97
Mar 9, 2007 10:55 PM
rmistry7
Sep 28, 2006 05:05 PM
Jan 18, 2005 07:46 AM
